Hi All,
I am a new member here with a 1990 Camry sedan (SV21) previously driven by my daughter.
I drive the car generally on short trips and for shopping.
I am looking to replace the shockers front and back and need the following answers:-
1. How to diconnect the brake lines from the brackets welded to the struts. I have considered cutting the bracket, slide the brake line away and drop the strut. What to do then on re assemby?
2. I am looking to use Ultima shockers made in Australia (Queensland) I believe. What is the opinion of these? Has anyone else used them?
Your comments are appreciated.
Matt
There must be someone who is familiar with this issue or someone who has had this work done to their car.
I appreciate the advice/experience.
There should be a tag on the bracket that you can remove. Just use a pair of pliers or vice-grips to pull it out.
Thanks mick I will have a closer look.
Does anyone have any experience with Ultima shockers?
Has anyone fitted these to their cars?
never heard of them tbh... I normally use KYB or Koni shocks.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
