ZZE122R Air Conditioning Condenser
2204
found a leak in my air con condenser needs replacement only thing is they make 2 different ones for the zze122 corolla so which one is my one? mine is a 2006 corolla sedan automatic below are the 2 links the pictures will show the difference, cheers david.
http://www.ebay.com....a#ht_1289wt_952
http://www.ebay.com....7#ht_1254wt_952
Edited by 2204
the first one if your a/c lines go down opposite sides of the carfrom the firewall (mostly prefacelift), the second one if your ac lines both run together from the firewall to the front of the car(mostly facelift)
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
