Posted (edited)
my 1993 corolla rv has no power no lights no central locking nothing could it be a relay problem ? help please
battery fine jump started nothing no lights the only thing working is taco is going wild ?
Edited by mindy
alternator is making winding noises when key is in ignition position,
jump starting has no effect. relay was working ok
Bad earth somewhere maybe?
Have to done any work to the electrical system on the car lately?
With the alternator is it making funny noises when the engine is running or is it only while the ignition is in ON.
I cant start the car there is no power no lights on dash no headlights no central locking nothing. when I put key in ignition the taco goes crazy I can hear a whining noise coming from the altinator nothing elese is working
Have you checked all the fueses in the car?
Checked for any loose wiring on the car?
yes checked all fuses & relays all working no loose wires just no power ?
  • 4 months later...
simple, shiity battery earth , by a battery reamer tool and do both terminals
I 2nd that its an earth problem, Clean all earth contact areas with sand paper if need be. Good luck.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
