Hi all,
I was looking to upgrade the headunit in my 2005 Corolla with a 2013 Corolla headunit (not the reverse camera one).
I was wondering if anyone had done this before, or weather it is possible.ie. will the headunit fit size wise and will I need to modify the wiring. If the 2013 unit is to difficult to fit, which year model headunit will fit straight into the 2005
I have looked at headunits in car audio shops and I don't like any of them, plus I prefer the genuine look.
Any help would be great,
Cheers
Scott
Hey Scott80,
Size wise you should be ok. Also I don't see why there would be tooo many problems with the wiring, OEM all the way I would think.
/my2 cents
Thanks for the reply NIX. I think I'll get it, see if it works and report back here on the outcome.
Cheers
Scott
Hi all,
Cheers
Scott
Yep Ive done it and it fits like a glove.
Plug and play except for the Antenna wire.
You need to get an adapter for the old Style ZZE antenna to match the new style connector.
The antenna also needs 12Volts running to it so you have to join the adapter to the old wiring harness with scothlocks or solder.
Get the adapter on Ebay :
http://www.ebay.com.au/itm/CONNECTS-2-CT27AA93-TOYOTA-ALL-MODELS-UP-TO-2013-DIN-FEMALE-AERIAL-ANTENNA-/380694591710?pt=UK_Cars_Parts_Vehicles_Terminals_Cabling_ET&hash=item58a32a78de&_uhb=1
Cheers !
Wot... I assumed all antennas are the same? So stupid for Toyota to make it a different plug -_-
Sorry to hijack... But it's a similar question. Would a 2008 Prado stereo fit a 2003 Corolla? Size looks similar...
yep 2008 Prado stereo will fit, plug and play.
they're called a "double din" size
will fit all corolla ZZE or ZRE
better off buying a late model Corolla stereo, plug and play except for antenna adapter required.
they come with bluetooth and voice activation, MP3/WMA, USB
look on Ebay
http://www.ebay.com.au/itm/Toyota-Radio-Cd-Stereo-Bluetooth-Hilux-/321285188446?pt=AU_Car_Parts_Accessories&hash=item4ace16eb5e&_uhb=1
or
Touch Screen unit
http://www.ebay.com.au/itm/genuine-toyota-touch-screen-head-unit-/221344352176?pt=AU_Car_Parts_Accessories&hash=item338926c7b0&_uhb=1
cheers
So the Prado one is not plug and play? Or would it just require the same antenna adaptor?
08 prado is plug and play. It fits in the hole perfectly. The speaker and power connections are the same.
I'm not sure whether you need the antenna adapter or not.
The old style plug is round and about 8 mm diameter.
The new style plug is rectangular.
The adapter is about $15 on eBay. The antenna lead plugs into it then it plugs into the headunit.
Cheers
Posted (edited)
Just got my hands on a pzq60 00514 headunit.
Ordered the antenna adaptor cable as well.
Will let you know how it goes!
Thanks for your help.
Edited by C-rolla
Cool C-rolla.
I haven't had any success getting a new head unit yet, but I'm still hunting Ebay and Gumtree.
Yeah I was lucky with mine. Been looking for awhile, Hopefully the install isn't too tricky for me. We'll see how we go.
Posted (edited)
Hi all,
Cheers
Scott
Cheers !
Hi there,
Just a quick question.. is there anywhere in particular that one should solder the antenna adapter to on the wiring harness?
Cheers.
Edited by C-rolla
When you remove the old CD Player you will see there is a thin wire next to the antenna wire.
The blue thin wire coming from the new antenna adapter needs to be connected to the thin wire going to the antenna.
The antenna adapter should look like the one below.
Hope that makes sense
KGrHqFHJCsE905hZHKBPgDOqSUF60_12_zpsf74c
Posted (edited)
_________________________________________
does indeed... thanks mate.
installing over the weekend.
cheers.
Edited by C-rolla
Hi guys
Thank you for all the help rolla02 - spent some time yesterday putting in the new radio.
Was really easy and works perfectly.
Next thing is to change over the fascia lights from green to blue.
Anyone know the size of the bulbs so I know what size light caps/condoms to buy?
Cheers!
  • 5 weeks later...
Posted (edited)
Hey Guys,
Just did this same thing to my 05 corolla but didnt use the blue wire from the aerial adaptor for anything.
Noob question but will that be problematic? Will it cause a drain on my battery or is it just to boost the signal of the aerial?
Thanks for any advice.
Edited by Daewon
apparently there's an amplifier built in to the antenna base on ZZE corollas
it needs 12 v
the radio doesnt work that well without the power.
Hey Guys,
Hey mate,
I just got a Head Unit (finally), and installed it without the aerial adaptor, which is being shipped to me as I type this. The head unit seems to work just fine, but obviously no radio reception. I will be installing the adaptor as soon as it gets here and let you know any changes.
Cheers
Scott
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
