Help Please. Have a 2001 hilux which gas done a lot of km decided to overhaul motor. Pulled it out and had it fully rebuilt internaly. Had the turbo rebulit, injectors overhauled, new clutch, a brand new injector pump, oil air and fuel filters of course, radiator cleaned and tested water pump, glow plugs, etc. Essentialy everything that needed to be replaced has been of overhauled. It fired up with no problem sounded great drove it for 25 km and it lost power and wont rev over 1500 rpm blows white smoke engine light will come on sometimes code flashed out is 14 which refers to timing control valve system malfuction. Injector pump is brand new and solenoid tests ok wiring from all sensors on motor to ecu have contiuity and no shorts to ground or power. Have tryed another ecu and it still does the same thing, have had another throttle body on it also, fuel is clean and has no restrictions. Valve timing has been checked ok. Not sure where to go now
:huh: :(
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
