Hey guys I've got an issue that I would like to put past you. I have a rebuilt 2LT 1984. It will drive fine for a few minutes then loses all power then stalls. Can keep the engine alive if I feather the throttle it will keep running but as soon as I stop feathering it stalls. It's time between these occurrences has been shortening from 20mins down it happening every 5 mins. If I let it stall then start it again it will run for a few mins before it happens again does take longer to start then it should (5 second start when hot). The car runs within temps (80/ degrees) turbo runs 8-10psi(3000rpm)
things I have replaced.
-Relays
-Diesel pump(2LT pump. And 2L pump) with turbo and without.
-Turbo run with and with out it on.
-Exhaust
-different oil
Any help on this would be greatly appreciated it's a mates pride and joy.
Hi there,
Try to change fuel filter if you didn't maybe is blocked.
Also check if you may have dirty fuel tank.
Regards
Noel
Drain filter first-theres a tap underneath it--you might have a blown globe in your water in filter light--does it come on whith just ign? Is the float assembly fitted and wired in base of filter?
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
