1999 Prado Starter motor problem
Mbee
Hi all.
I am a newbie to this forum and have a problem with the starter motor on colder mornings, it will not turn over every time I try to start the car, after warmup it works fine.
The engine is a 3400 v6 and has done 200,000 Km without a problem. I hope somebody can suggest a solution.
Regards
Mick
  • 3 months later...
  • 2 months later...
The starter motor on my 2000 TDI prado is on the way out too. It will sometimes engage and start the engine
and sometimes it will spin.
Given im on 420K, I'm going to get a replacement off ebay and swap it out, although I hear thats
a bit of work which involves removing the front wheel and disconnecting the brake line
Hi Kiwi-Red
I found the answer with my problem, it was the solenoid contacts. They are replaceable at low cost aprox $20.00, and easy to replace.
There are a number of different types depending on the model, but if you take the parts to an auto electrician they should be able to help.
  • 7 years later...
      alarm for Hiace
    2. 3
      Toyota 2006 Kluger Grande 3.5 L - at about 55kph vibration
    3. 9
      Stedi H11 Projector LEDs
    4. 9
    5. 1
      Engine Oil 1GD FTV
    6. 1
      Engine Oil 1GD FTV
    7. 0
      Bluetooth connects, disconnects, over and over.
      Tyres- 2020 2wd hybrid
    9. 3
      2022 RAV4 Hybrid tow bar
