will they fit?
right now i'm rolling on oem rx8 wheels on my auris mk1 with no issues at all even while lowered but i'm fancying a change. would like to know if someone tried fitting 9.5 19 inch rims.
as you said it was too fatty as it is a concave design. it would have looked sweet if my ride was bagged but it's my daily and it poked out roughly by 5-10mm. the strut side didn't seem to be the problem. for once my common sense prevailed on my instinct and went 8x18 in front and 9x18 rear. i might lower the rear a bit more as i lowered the tire profile now.
This car has 19x8.5 +43 front and 19x9.5 +38 with 225/35 F and 235/35 R tyres
Also has 10mm spacers on front, not sure if they are for looks or needed to clear the struts.. You have some homework to do ;)
post-9535-0-33968600-1408530803_thumb.jp
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
