Have a rn105, idiot that did the conversion cut a bonnet support to fit the commo radiator in instead of using the existing radiator.
Before I go forking out for a new radiator, just wanted to make sure there's no issues/pitfalls using the rn105 radiator with the v6?
This is going to be a bit of pot luck in finding someone that has done the exact swap.
From what I've been able to gather, the v6 commo conversion is a pretty standard transplant.
That is true, but there may not be many/any members here that have completed it. You could also try Commodore based forums, as well as Hilux/4WD specific forums.
compare both motor power outputs. if the commodeor is similar it will be ok. tolerance abt 10% at most. Radiator MUST be big enough to handle motor kw dissipation... There are calculations for it online. I will guess and suggest you'll need ther best cooling you can get. That might be a tripple core brass core, or it might be an aluminium radiator. I don't know which. The Ali rads have plastic tanks, which eventually rupture near the top inlet due to thermal stress.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
