Hey, my remote casing to my Hilux has recently been cracked and is pretty much falling apart. I was wondering if I could buy new casing for it and just change the internals without having to reprogram it?
Yes you can. With the new key you should get the key blade cut to code and not copied off your worn key. The shells break because the key becomes worn and you use more force to turn it, therefore breaking the plastic. If you get all that wear copied on to your "new" key then it wont last long.
u can buy the case on ebay pretty cheap,not sure about the rest,but if u try give the conctacts a clean with metho buff them of with something really clean while your at it
( Dont drown em just damp)
Good luck
B
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
