Difference between CSi, Conquest etc.
Hello to all!
I'll be moving to Melbourne in a few months and am canvassing for a first car. I happen to like this particular Corolla model and well, my budget is in this range.
I tried looking at used car websites, and all I know is that the CSi is an entry-level variant compared to the Conquest. So what does the Conquest have that the CSi doesn't? I tried searching the forum as well, but to avail. Kindly help me out here.
Thanks in advance. :)
Hello to all!
i think the CSi is 1.6L engine with 13" wheels while the Conquest is equip with 1.8L 85kw engine.
All models with the 1.8l (7A-FE) have 4 wheel discs. To the best of my knowledge, the models go CSi, then Conquest, then CS-X, then RV, then Ultima. RV is Seca-only and Ultima is auto-sedan-only (info from a '94 copy of Wheels that I had lying around).
All models were available in 1.8l so yours could be anything. As per usual, most of the differences between variants are just specification :)
you going for sedan or hatch? (or even the import Liftback Levin??) manual or auto?
my dad has a prefacelift Conquest manual (95) and it still going strong.
Power and torque are the same in pre and facelift models. but the max torque in pre-facelift is at 2800rpm while the facelift max torque at 4800rpm...
Toyota didn't sell a Levin version of that model, you might be confusing it with the imported Corolla Sprinter (the first Corolla to break the $40G mark with a few options!)
That's what I'm talking 'BOUT! ... sorry, dunno how that bit of Marcia Hines got in there! :P
oh yes, that is the model i am talking about. i just called up the wrong name. thanks for your correction.
No worries ... that's actually my 3rd-favourite shape Toyota, beaten only by the original AE86 Sprinter in 2nd and of course, that oh-so-classy shape of the current Rolla wagon! :P
I'll be getting a sedan, manual, definitely with disc brakes all round and hopefully with ABS and driver's airbag. It will also be a treat if I can go for the 1.8. I would have also wanted power windows all-round, but as far as I know, only the Ultima has that feature, and it's only available in automatic.
Thanks for all the help.
....definitely with disc brakes all round ...... It will also be a treat if I can go for the 1.8. .....
You'll only get those brakes with a 1.8l to the best of my knowledge. So it will be a treat after all :)
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
