hi everyone,
i purchased a 2006 late model camry about a month ago now. It had 160000km on the clock and a full service history from the previous owner. The car has been faultless until now where i had noticed that the battery light and the abs light had turned on randomly after a short drive. i have installed an aftermarket bluetooth system, put in reverse sensors and led lights in the footwells, im not sure if they have had an impact on the battery light turning on.
has anyone had any similar issues or know why this has happened? thanks
Battery light usually indicates that either your battery or alternator has a fault.
Suggest putting your battery on a charger to see how long it takes to fully charge. Also check the connections at the alternator.
ABS light is commonly caused by one of the wheel sensors not working to specification.
If you have an OBD2 scanner, the error codes will indicate which sensor or other part is not functioning. Otherwise, you can clean the sensors and rings on each of the wheel hubs and hope that the light stays away.
    2. 9
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    7. 18
    8. 5
      Tow bar
