Digital Radio Unit SD Card Problem
xDiiThy
  • 5 weeks later...
On 7/7/2020 at 9:41 PM, CeeBee said:
Thanks Mate that worked for me as well Toyota Corolla 2015 NSW
Hi
Do u still have these files?Could u send to me a copy? The google drive link not working any more
On 11/14/2021 at 7:20 PM, Stephhhh said:
Hi all, I had luck with these files - hopefully they will work for you too 🙂
Stephhhh - Thank you, thank you, thank you.  The files you provided have worked a treat on my 2012 Yaris' PZQ60-00540 audio system.  I formatted an SD card FAT32 and copied the 4 files onto it. Then with ignition completely off inserted the SD card. Turned engine on, waited 10-20 seconds and to my great surprise and relief, the Toyota screen appeared and everything worked perfectly!!   (Back story:  The audio system has been completely blank and unresponsive for the last two weeks following a regular service at Toyota Camberwell - who after 'checking the unit' decided it was just coincidence that the unit failed at the same time as the service and quoted $1000 for a new unit. $1000! good grief.).  Thanks again, you have made my year.
  • 5 months later...
2013 corolla same issue after battery reset. Thanks all for helping. 24.07.22
Took 20 min all sorted 0 cost. This is the process I used 🙂
1. Delete all files from SD card (did not format SD card as computer accessed SD card O.K)
2. Download 4 files from google drive link
3. Open downloads on computer and copy the four files (best method otherwise tries to look for app to open)
4. Paste 4 files into SD card
5. Install in car - worked first time
Dan
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
