Hi guys
I just purchased a TRD AURION SL 2008 and i like some feed back on the sound of the engine ,it feel a bit like a diesel.is that normal or i need to check something .i read somewhere that they are a bit noisy .
Thank you .
Best if you can provide a sound recording and more details e.g. engine at idle; engine at 2000 rpm.
Rattle on startup, but goes away fairly quickly? vvti.
Noticable rattle on idle, but lessens as you increase the revs? Supercharger coupling.
For my trd Aurion it was the automatic belt tensioner a high squeaky noise on startup especially if it was cold
  • 5 weeks later...
From experience on my Grande/Presara engine rattle on start up is to do with oil pressure getting to the hydraulic lifters or air bubble in lifter. Rattle noise while running could be an alternator bearing or tensioner pulley.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
