Hi guys,
Had a question about an issue I am suffering with my Corolla (2007) Ascent.
Essentially the gauges (speed, odometer, rev), lights for cental column (air con, fan) are not turning on when I switch on.my headlights. They come eventually. Unfortunately, this may mean minutes without lights on my dashboard.
Basically, i can't clear see my speed at night.
Headlights and rears work fine. Internal lights above head switch on fine. No issues there.
Just my internals on dashboard that are suffering here.
I analysed the no.18 fuse (in engine compartment) for "internal lights"  but it is not blown.
Not an electrician. Could it be the relay though?
Any thoughts guys?
Thank you.
This may have some information as the issue seems similar. Apparently it's common on the earlier ZRE models also, possible a connector issue.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
