Posted (edited)
I've noticed that on rainy days if I press the brakes a bit harder, the wheels would lock which causes the car to drag forward along the road.
Yesterday I checked this in dry conditions and while I was only doing 40kmph, I still feel the wheels would lock.
I never saw an ABS warning light come on.
How should I proceed to resolve this? BTW, I have a 2007 Aurion ATX.
Edit:
Today I received a Check Engine warning and my OBDII sensor gave the P0500 error code. According to this, it could cause ABS to not function. https://www.obd-codes.com/p0500 Maybe this is the reason?
Cheers
Edited by nushydude
This URL may be of assistance. Diagram in the later post has a diagram showing the locations of the speed sensors on the transmission.
I would be inclined to remove the sensors and clean contacts etc.
How many kms on the odometer and has the transmission been serviced with a fluid change?
Posted (edited)
The car has done about 105000km.
Transmission should have been checked at the 90000km service. But I don't know for sure if they replaced the fluid.
Edited by nushydude
My 2006 Aurion AT-X with about 166,000kms on the odometer was an opportunity eBay purchase. Afterwards, I did the research about the engine and transmission. I dropped the transmission pan and replaced the transmission filter and fluid [as high priority preventative maintenance task]. As forewarned, there was a fair amount of "sludge" coating the bottom of the transmission pan.
This is why I would be inclined to check the speed sensors and clean off any accumulated coating as a starting point.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
