This must have been covered but i couldn't see it in the posts?
anybody have an easy way to remove the rear axle bearings? - i dont have a press or the magic tool at hand just here.
600k on a dying bearing.... its gonna be ugly :laugh:
Ta dude,-
Yup - seems to be the most common after market approach....
did the same job on a Rodeo which have the same setup - all the "lightweight" utes do i think (semi floating axles)
in the end it was a case of remove - take to the "lord of the special tool" & replace afterwards. The tool is $200 & if i was planning on replacing the bearings often.... hopefully not! - then i guess its worth buying one.
Unless you have all the gear, it's not really a DIY job.
Best bet is to remove the axle yourself and take it to a workshop to remove and replace the bearing. Will save you labour dollars.
Mate, it's better off to just remove the axle and take it to a Toyota dealer or Pedders workshop and get them to fit a new one it.
You could buy or make the tooling needed, but for a one off job it wouldn't be worthwhile.
Roger  Roger...
I sorted that out a while ago now but for anybody else considering this issue -
Some people blow the bearings out of the cage with an oxy.... :blink:  then slice off the inner race with a grinder
Some just attack it with the grinder... & then beat the crap out of it all... :biggrin:
I went the easier approach & did everything i could but had the old bearing pressed off & then new on.
I've heard Toyota have charged people up to $500 for this..... :ohmy:  In the past I have been charged $200 for the same service elsewhere.
If you are in Melbourne then i would happily recommend Tyresplus Newport - they did a nice neat quick job & only charged $80 for the press off & on. I supplied bearings & did everything else.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
