Hello everyone,
My hilux's horn is never been working properly since I've bought it, it was working only while turning the wheel and then it stopped! Any idea what it is?
Not a fuse and not the horn itself, it must be something in the wheel... What can I do?
Thanks a lot if someone will help
You can pull the wheel off and have a look. Be sure to mark the wheel position in relation to the shaft.
There's a little contact on a spring that wears out. Just add some soldier to the contact and it should be good for ages. Also clean and lubricate the contact point on the back of the steering wheel too. I'd recommend a tiny bit of Vaseline on the contact surface of the steering wheel
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
