2004 Toyota Camry 2.4, 4CYL Sportivo Loud Vibration
ZRCamry04
Hi got a loud vibration sound when car is in drive and with a/c on, not as loud when a/c is off but still present, what could be the issue.
Edited by ZRCamry04
9 hours ago, trentmeyer23 said:
I would service the auto, giving it a good flush.
Definitely do the auto transmission flush especially if the ATF has never been changed and done 160,000kms.
Toyota Camry ATF Transmission Fluid Flush.docx
Flush is the preferred option as it replaces all of the used ATF with new. If you are not comfortable about doing the flush, then drain and refill the transmission pan. Drive around the block and repeat the ATF drain and refill. Overall, you will need to do about four [4] ATF drain and refill of the transmission pans to replace most of the used ATF.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
