Ignition coil lifespan for ZRE152
  • 6 months later...
Just noticed an eBay seller saying that the recpmmended replacement of ignition coil for a Toyota was 10 years or 100,000 miles [160,000 kms].
In October, I replaced an original coil on a 2007 Yaris with about 190,000 kms on the odometer after it threw up a check engine light. Spark plugs also ended up being very worn and well overdue for replacement which was done. I am thinking that if the spark plugs had been replaced earlier then there would have been less demand/stress on the ignition coils.
This weekend, I have replaced the spark plugs and all of the ignition coils on my Toyota Aurion which has done 204,750kms. Previous owner would have had the spark plugs replaced probably at 100,000kms and it is most likely that the DENSO ignition coils were originals.
    3. 21
    4. 21
    6. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    9. 7
      Help - Blowing white smoke
