Hey guys and gals.
Had a look yesterday at the new Hilux Rugged. What a beasty looking machine. Had a few questions about it that the salesman couldn't answer. 1.what is the current Hilux's engine model? (Was handed a full 11 page vehicle spec sheet that didn't have the model in it). Does anyone know the current engine used? Trying to do research and see if they have fixed the DPF issue before buying.
2. The sports bar is built into the chassis itself so they can't be fully removed to allow a standard canopy. They were almost disgusted when i pointed out that the top half of it is only bolted on so it can be removed and the lower half can be used as a mounting frame or tie down point in the tray. Question is has anyone fitted a custom or standard canopy to the new Rugged/x?
I can tell you that they have the 1GD engine but know nothing about the DPF.
You can unbolt the l sports bar and remove it. I can't see why a canopy can't be fitted. If it's all standard from the top half imo.
      Turboed Corolla Overbuilt?
    2. 3
    3. 3
    4. 0
    5. 6
    6. 18
    7. 5
      Tow bar
    9. 3
    10. 0
