2013 d4d Engine Swap into a 2007
Shanecane
Hi All,
I purchased a 2013 diesel engine with a loom for my 2007 chassis, I found I had to change the injection computer, but now I don't have any power to the starter motor solenoid.
Can anyone help also is their any other changes or differences
the injection controller loom is a 7 pin plug but the 2007 plug was a 4 pin
the harness was attached to the engine when we swapped it over it as it was easier
You'll need to replace the loom with the original look and ecu. You will also need to put the original injectors into the new engine as they are different and cannot be coded to the original ecu.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
