BOOT LATCH RELEASE
The boot latch release inside the car (on floor next to the driver's side) is broken. Pull it up and it is just loose and doesn't open boot. Any suggestion whether this is a diy fix or who or where to have it fixed at a reasonable price? Cheers -
Hi, thought I'd take the cheap route (rather than Toyota's quote of near $350!!) and buy a replacement fob off ebay $20.... helluva difference. Unfortunately, I reach the last stage in the instructions but "locks should cycle once for correct programming, or twice if procedure is incomplete". Nothing happens and the fob is not programmed. I've tried so many times . Any suggestions please? I did see an answer on here that perhaps the "memory" for the number of devices is full and would need to wipe all memory and start again. I'm too scared to do this for my one and only original fob, in case it doesn't work :(( Cheers -
13
The car is going great now and it was a mechanic called Adam at Brutton Automotive Windsor NSW. I am so impressed with the customer service from this young man, he has gone above and beyond in the times I have taken my vehicle to him.- 1
Hi l have a 2000 vx Prado and the small cylinder on the right of the master cylinder is making a churping noise. It occurs randomly but is most prevalent when brakes are applied. The pipes going to the offending area vibrate when noise is on. Is there a remedy. -
I have concluded that there is water leaking into one or more cylinders due to a failing head gasket. It most likely is original and has done well to last for 32 years. Composite gasket. I plan to pull it apart and have the head checked and machined in the usual way, and change the timing belt and water pump etc. while I am at it. I'll mark the thread as solved. Jim. -
Tyre tread damage
Thanks for the suggestion. Just came back from another shop this arvo. It feels much better now.🙂 -
Ever get this figured out? Mines just started having the same issue -
Changed my mind again, (last time 😁) Method Race Wheels 703-HD Bead Grip Matte Black 18x9 6x139.5 +40ET ZMR70389060540H, Micky Thompson BAJA BOSS A/T 275/70/R18 33.2 inch and largest legal size with the 2 inch lift. 1.6 inch larger than standard. Cheers JA -
OBD port lock for 300 series
Latest news suggest that car thieves are now using the OBD port to steal 300 series. Has anyone found a decent OBD port lock that works with the embedded OBD port in 300 series? -
Hey all! Recently upgraded from a 2009 Kluger Grande to a 2017 Kluger GXL... the 2009 was decked out with a round chrome nudge bar and all, making it easy to mount a UHF antenna up front! But, this newer model I have gone with the OEM Toyota nudge bar that I really like the sleeker look of, but it does not give me anywhere to mount a UHF antenna, and even more so, I cannot seem to find any bonnet hinge mounts for this year model available online! Not really wanting to go with any thoughts or suggestions greatly appreciated! Cheers!
