Water in my workmate door
Bulldogs195461
We have had some heavy rain this weekend, my workmate is 12 months old, today I could hear this swishing sound in the door, just checked it and sure enough there is water in the door, can anyone let me know how to release it, or give me a reason for it happening.
Cheers john
Check along the bottom of the door skin for drain holes, these are most likely clogged (just poke them out with an old coathanger).  You'll always get water in the door as the window tracks cannot seat perfectly, but if it drains properly then you shouldn't have any problems (the electrics inside the door are either sealed or separated from the water by a plastic sheet/skin)
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
