Master cylinder / ABS module
Clive Davies
A very long story that started with replacing the rear diff oil seal that has eventually ended up with a vehicle with no brakes.
I have fitted new pistons into the master cylinder, however I cannot get any pressure into the system. I suppose the next step is the ABS module or is there more to be done with the master cylinder?
The system drained of brake fluid while the rear calipers were removed during the seal replacement (recommended by Gregory's, however on review, that may not have been necessary) which I suspect created the current mess.
Has anyone got any ideas to share?
3.0l Diesel.
Edited by Clive Davies
forgot vehicle details
      Toyota Corolla 2012 zre152 transmission issue
    2. 46
      Lowering a Corolla ZRE
    3. 3
    4. 1
    5. 3
    6. 23
      Transmission U660e
    7. 3
    8. 4
    9. 7
