Hi all.
On My 2010 Toyota Aurion has a shaking belt tensioner assy.
Any hlep?
Best to properly diagnose the issue before throwing parts and time and effort at it.
Some YouTube videos will show how to release the tension on the serpentine belt. From there you can check out the amount of movement [if any] in the tensioner assembly and the pulley. YouTube videos will show how to repack a sealed bearing. I used Castrol LMM grease to repack both of the idler pulleys for the serpentine belt when I was replacing the alternator.
If badly worn, the pulley will need to be replaced.
https://www.ebay.com.au/itm/Fits-TOYOTA-AURION-HV-GSV40-Idler-Tensioner-Drive-Belt-Bearing-Pulley/264099642698?epid=20027346004&hash=item3d7d90bd4a:g:tE0AAOSw1KRcHtYq&frcectupt=true
Possible worst case scenario is that tensioner assembly will need to be replaced.
https://www.ebay.com.au/itm/DAYCO-FOR-TOYOTA-RAV-4-KLUGER-AURION-TARAGO-2GRFE-DRIVE-BELT-TENSIONER-PULLEY/142477518529?fits=Model%3AAurion&hash=item212c5266c1:g:qCUAAOSwLs5XKDK-&frcectupt=true
On 6/27/2019 at 8:10 AM, jacko16 said:
Hi all.
Any hlep?
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
