Transmission oil seal
LordBug
Hi all,
I'm going to be replacing the axle oil seals on my ronron, and I'm at a little bit of a loss.
The manual for the U660E transmission names the two seals as "no.1" and "no.2" case seals, but no part numbers for them. I've managed to find the seal marked as no.1, but I'm having no joy with no.2 - it kind of looks like they're two different seals since installation uses a different SST depending on which one, but my google-fu is failing me and I can't find any clear proof of such a seal existing (or in some cases there are three or four different seals of differing dimensions). If anyone can shed any light on this particular mystery I will be forever in your debt
Cheers,
I went to Amayama.com and looked at the Parts Catalog
90311-50033 01 05.2006 SEAL, OIL, NO.2 (FOR TRANSAXLE CASE) GSV40
90311-40029 01 05.2006 SEAL, OIL, NO.1 (FOR FRONT TRANSAXLE CASE) GSV40
You have probably already seen this
http://www.tovenza.com/differential_oil_seal-852.html
You sir are my saviour! I'll be making good use of Amayama in the future 🙂
And yep, that is the same as what's in the service manual.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
