Hey guys,
Anyone know if theres a stock grounding point in the boot that i can ground my amp on? Or is there a spot that is good for grounding amps in the boot. Trying to avoid drilling a hole myself.
Sent from my iPhone using Tapatalk
Yes but you will have to go looking for them yourself.
I would start by looking underneath the rear parcel shelf for a bolt hole before removing any of the trim.
I am sure that there is a grounding point on the passenger side for the towbar bar wiring. Otherwise, it will be a case of going to the rear lights area looking for the grounding points there.
Attached is a link to the wiring diagram for the GSV40 series. Have a look at page 401.
https://toyotacar-co.com/wp-content/uploads/2016/05/g8M-AXq3BUPu8lmh3uafTXUgHpA1ew8p.pdf
Posted (edited)
There's one next to the left/pass tail light behind the trim panel on the GSV50R, I'm guessing same or similar to GSV40R
Edited by ZZT86
      Android auto
    2. 1
      Turboed Corolla Overbuilt?
    3. 3
    4. 3
    6. 6
    7. 18
    8. 5
      Tow bar
    10. 3
