Hi All,
I have a BT31SY bar (https://portal.ecb.com.au/products/31713?page=35&searchMake=&searchModel=&searchVariant=) with no mounting kit.
I've been unable to source a kit from the supplier, ECB.
Is there anywhere on/offline where I can purchase the mounting kit for this bar?
I am located in Sydney but happy to pay for shipping.
Cheers,
Chris
Good luck with that, i have an alloy bar as a spare now as of the problem your having, my only option was to take the car and the bar to metal engineering shop and ask them to fabricate the brackets that i need, but you also need the fitting instructions, and I'm glad i had this one professionally fitted, so now if anything happens i have a replacement bar that i can use.
      Hi, new QLD member
    2. 1
      3MZ-FE Low RPM Hesitation & Rough Idle – Stuck VVT?
    3. 1
      ABS brakes on 100 series sahara
    4. 1
    5. 1
    6. 2
      over heating
    7. 2
      over heating
    8. 11
      Tyre tread damage
    9. 11
      Tyre tread damage
    10. 11
      Tyre tread damage
