ey guys today in my 2005 n70 I was finding it really hard to change gears and reverse was the worst im having a few problems with my rear diff at the moment but not sure if it’s that or my gear box but as soon as I turned my car off I could shift again easily?? Any answers would help right now thanks.
Reading your issue has reminded me of videos showing movement in the drive train between the transmission and rear differential. Probably a good idea to check the bushings and drivehaft bearings for any movement.
Interest to see any future posts of what the cause ended up being.
I'm ssuming it's a manual. Is that correct ? There was no mention. Given the hard life most of these Hilux's get, I wouldn't be surprised if you have premature wear and tear on both tranny and diff. When was the last time the fluids were checked/changed ??
Certainly would be checking the rest of the drive train too as Ashley pointed out.
Has it a hydraulic clutch system  , might check its operation looking further maybe the clutch.
  • 2 years later...
I also have issues with a new (to me) 2001 Hilux 4WD 3L diesel shifting 4>3 while moving. Easy to shift any gear from any other while stationary, but 4>3 whilst moving is nearly impossible to get, even with a lot of force it is only about 30% success. I have to go 4>2>3 while clutch is depressed, to reliably change 4>3.
As I have only had the ute a week, I would hope to get some guidance on the fault finding and remediation of this issue.
Thanks in Advance,
Tony
Would be saying your syncro s worn ,when driving the whole cluster is rotating ,stationary only the input shaft is no load on the box so shiftings easy
Thanks for your reply..You may be correct, but I will need to continue to shift 4>2>3 when shifting 4>3 as I cannot afford a gearbox overhaul.
Quote
I believe that your diagnosis is correct. If I double clutch while shifting down it goes in easily, so Double clutching while downshifting is what I will be doing.
Tony
