Posted (edited)
Hi guys,
I have a 2008 Touring. My job often involves long periods sitting in my parked car. Is it a DIY job to rewire the stock radio so that it operates without the ignition switch being in the accessories position?
The reason I ask is because I also have a dashcam which has a parking mode. When the ignition switch is in the accessories position, the dashcam operates continuously which is not what I want when I am parked and listening to the radio.
Edited by Jacaranda
Wire a switch on the dash cam power cable and turn it off when you are in this mode.
On 1/4/2022 at 2:30 PM, Sebastian Woodhouse said:
Change the Dashcam to be powered r the ON position.
Then parking mode won't work.
      Has anyone had issues re-installing intake camshaft 5SFE
    2. 1
      Toyota Crown GS130 He****
    3. 7
      Current Drain
    4. 7
      Park Brake Adjustment
    5. 7
    6. 2
      Gidday y'all
    7. 4
      Aircon problem need help
    8. 4
      Anyone had this Issue
    9. 1
      Camry high rise spoiler
