Lighting bar in front of cruise control radar
Patf
I have 2018 Prado with radar for cruise control behind the Toyota badge I’m front grill.  I want to mount LED lighting bar on the nudge bar but am concerned that it might interfere with the adaptive cruise control and safety braking.   Has anyone any experience of this?  Thank you.
You could do a mock up install of an object of the same dimension as your lighting bar and then do a dry run with it. This way you would know definitively if it will work or not before you commit to the actual install.
Position a piece of timber of the same thickness, width and depth with some gaffa tape, gorilla tape or similar in the very spot you intend to mount the light and go for a drive and see.
    2. 2
    3. 23
      Transmission U660e
    4. 2
    5. 4
    6. 7
    7. 1
      New Guy....
      Gauge Pillar JZX100
      JZX100 CHASER A Pillar gauge pod
