Hi All,  We have an issue with the low fuel light flashing, the book says to immediately contact our service agent.  We asked Toyota about it and some service people said they either did not know what is going on and others said it could be that the pump between the sub tank and main tank is no longer working, the fuel gets into the sub tank by Venturi and then gets pumped back into the main tank.  As a result we can only use about 90L of fuel and when We add diesel from a bowser the fuel froths up block the inlet neck and only three quarter fills the tank.  To replace the pump is a major undertaking, min $5,000 to investigate with no guarantee that will solve the problem, most advise not to allow the tank to get below one quarter.  Can someone assist.  Is this the this a correct diagnosis? Cheers Aleks
  • 1 year later...
Hi Alex,
I have this issue, did you solve it?
Kind regards.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
