Posted (edited)
i have forgotten that ive had it in 2nd gear and reached 80ks is that bad? lol
its happened more than once lol
also im having a rev/gearbox problem ? its revs high then then changes gear when taking off sometimes not all the time.
Ill just go to a gear box place and ask them since no one knows :P
lol i know the majority have manual gear boxes ^_^
Edited by ChArMs
mm...how hard do u step on ur gas pedal when taking off......if u floor ur gas pedal then the car won't change gear till 6000rpm......also 2nd gear can go to 80km/hr...1st gear cut off for an auto is 60km/hr..
just try not to do it too often......
It could, it just depends how many revs the engine was pulling at that speed.
When you say it rev's high and changes gear, do you mean it changes when it's not supposed to?
When you take off hard in an auto (Old or New) it will hold first gear longer than when you take off gently, it can also 'kick down' to a lower gear when you're already rolling along at speed and you boot it. This is normal.
An auto transmissions can be subject to a condition called slipping. Quite simply this is when the transmission tries to hold a gear, but slips in and out of gear, resulting in the engine revs flaring and usually and big thud or worse, when the car just wont take off. This can be caused by a couple of different things, lack of oil or, simply due for an adjustment of the belts (service).
Hsien Posted Today, 02:25 PM
lol usually to the floor
i dont have a rev reader do any autos have them ?
ah k so i have nothing to worry about
IZZ-FE Posted Today, 04:45 PM
when i take off it revs high for about 5 secs ruff estimate then changes gear
i think it might need a servie hopfully it wont cost to much
thanks guys for the replies :)
    3. 9
    4. 9
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
