Greetings!
I have a 2008 camry 2grfe 6 speed a/t, while driving along the highway the dash  lighted up suddenly with engine,  trac, and vsc warnings, so i hooked up my code reader and a p0365 was diagnosed, honestly the p0365 didn't affect the car's driving characteristic (or I just don't know?) Have anyone of you encountered this code,  and it's it safe to drive while this code is appearing all the time, thanks in advance
As a general rule, error codes should be investigated and resolved ASAP. I would start by checking the electrical connection to the camshaft position sensor. Next possible step would be remove the sensor and check/clean any oil sludge. Last step would be reset/clear the error code, If the code reappears then consider replacing the sensor.
https://www.engine-codes.com/p0365_toyota.html
Just an update, i manage to clear the problem by replacing the camshaft sensor bank 1 sensor b, was quite a tough job reaching the sensor near the firewall but nevertheless, succeded in eliminating the trac, vsc, and engine lights, been driving it for a week now and hopefully its truly fixed
