Tyre Sale Specials
P0303, rough idle, check VSC message.
Any photos or videos? Would love to be able to do the rear plugs and coils without the hassle of removing the intake etc. Also, how do you order parts from the Goss Mechatronics website or did you get it from somewhere else? -
4
P0356 - Ignition Coil 'F' Primary Control Circuit/Open
Thanks for the video Ashley. Yes my connector tab also broke when I did the coil change mentioned above. I just put it back on without the locking tab and it hasn't come loose in the 8 months I've been driving it since. But now I will do this cable tie trick to be a safe. Thanks again. -
I've just started having the same problem with my 2016 VX thats done 220,000kms. Plus the AC is so cold and won't generate any heat into the cabin and has just started leaking water/liquid into front passenger seat footwell. Would appreciate any tips anyone can give thanks. -
Head unit installation on HZJ79
Hey team I am currently installing a new head unit and speakers, I have got everything wired up and power is going to the head unit, but I am getting now sound, just wondering before I start trading all the wires to the speakers. Is there anything simple that might fix that, I know on some cars that you have to disconnect the factory amplifier, but I cannot find one yet. Just looking for advice what it could be. It is a 2002 Hzj79 -
Replacing the ignition barrel on 2007 100S LC
You can try nice locks & wheel nuts in Alexandria in Sydney they will have the complete new lock assembly all you will have to do is drill out the 2 shear head bolts & the lock housing comes apart fit the new assembly tighten up the new bolts till the heads shear off. Ray. -
I have a defective ignition barrel on a 2007 model 100 series landcruiser. I have purchased a replacement barrel with new keys from Toyota and also watched the available UTube videos. The original key was stuck in the ignition and would not turn in any direction. I have finally been able yo remove this key but the ignition will still not turn. The switch position is somewhere close to the Acc position but not very sure if that is right. The radio does turn on but that is all. I cannot move the switch to a position to where I can feel the lock button engage so that I can push it down so that I can remove the barrel. Can anyone give me an answer to this problem please. Thanks Spikeke -
Anti theft code
Hi guys I bought second hand car and it was in garage for long time and now it asking for code but I don’t any code. Any help would be much appreciated. -
7
Very happy to report success! I did it by just removing the cowl, didn't touch the plenum or anything else. I only changed the one plug and coil. They both look fine. The plug was a NGK DILFR6D11. The coil was a VDO brand. Replaced with the same plug $23 and a $55 coil from Goss Mechtronics. I used the masking tape method to mark the wipers position on the windscreen. I removed the right side bonnet strut at the top and used a stick to hold it open from the from. It made it much easier. Idle nice and smooth and the error code is gone. Fingers and toes are crossed. Thanks for the comments.- 1
Engine upgrade ideas for 1991 LN106 3L
Looking for ideas on a reliable engine upgrade for a Hilux 1991 LN106 3L. Just in the early planning stages at the moment. Located in Queensland - reliability, "non-electronic" and road legal are main priority areas for me, happy to go turbo. Not looking for crazy perfomance but something better than the stock standard (and now tired) 3L. Any ideas fromt the brains trust would be great! -
Rear Tail lights - LED or normal bulbs
Does anyone know if the rear taillights are LED or normal Bulbs? The brake lights dont appear to be working so i thought id check first before pulling it out.
