Hey,
Planning to put a 2uz in my 105. Was looking at transmission options and the A750f looks like the most obvious one, but I wanted to see if I could get a 6 speed for better fuel economy. Hence. the A761E.
I know it bolts straight onto the 3uz with the same output shaft and everything, and since the bellhousings across all UZ engines are the same it should do with the 2uz as well.
But, there is the question of the output shaft. I'm not concerned about the electronics, I'm doing a custom system for the ECU anyway, but I was wondering if the 3uz output shaft was the same as the 2uz, allowing it to be used with a A761E?
Any help would be much appreciated :)
      Brake Fluid Blues
    2. 16
      Brake issues
    3. 0
      Front Wheel Hub Bearings...
    4. 16
      Brake issues
      Intermittent power loss with 2013 Hilux turbo diesel
    6. 62
      Cleaning Engine Bay - Hints, Tips, Products?
    7. 0
      Rav4 2016 Missing Panel Replacements
    8. 1
      Ae112r 1998 keyless entry wiring help
      78 Series. Unable to get rear axle back in
    10. 1
      1997 Rav4 - Think I need a new engine
