New Member
Losing power when in gear from start off at traffic lights
Hi Darren, I have been following .... The Car Care Nut... on YouTube for various topics on the American "Highlander " which is our Australian Kluger. Not sure what is causing your problem however he has a video on MAF (Mass Air Flow) issues. MAYBE this could help you? OR their might be a video on his channel to assist? Hope this helps.. Safe Travels... Steve in Tamworth -
10
2004 Crown
Master warning light in the middle top between speedo and tacho. There's the letters PCS and a fairly long series of Japanese characters. Does anyone know what this might mean? -
Hilux door compatability
I have a 1997 Toyota hilux 2x4 and am on the hunt for a front left door. Would I be correct in buying any ln147 hilux front door or do I have to buy a 1997 hilux front door? -
Wherring noise engine bay when idle unsure if this is normal
Could be an Idler pulley, Alt bearing, water pump bearing, remove the drive belt and spin individually and listen fand feel for roughness, then start engine and see if noise is gone with belt off -
AE112 - Missing spare wheel in boot
Have just purchased an AE112 2001 Corolla with a missing spare wheel. I'm looking for a spare 14' Rim with a Tire. I'm having trouble locating one in northern NSW. Do you have any suggestions? -
AE112 - Headset Upgrade
I just purchased a nice little AE112 hatchback with 110,000 km. Is changing the headset a reasonably simple job? Anything I need to look out for? -
5
project 2007 camry grande
Toyota want $460 for the in dash clock , so i repaired the original , just re soldered the dry joint on the supply thermistor on the circuit board.The only difficult thing is to unclip the two connectors because the clips are located at the back. -
accessories Engel vs Dometic vs Evakool vs Bushman 4x4 fridge?
I've got an evakool 85litre and love it. It looks a bit wierd with the compressor on the outside but gives a nice big box shape inside with 2 baskets, which allow it to work as a fridge freezer. -
Fuel range displayed
Have got a 2017(I think) Prado we've replaced the standard multi media unit for a pioneer unit. We've lost the ability to see the range and fuel consumption. Is there a way to get this back? -
5
HUB ORNAMENT 42603-06110 only one in each packet $20.92 available at toyata dealers by order with three working days wait.
