Hi, thought I'd take the cheap route (rather than Toyota's quote of near $350!!) and buy a replacement fob off ebay $20.... helluva difference.
Unfortunately,  I reach the last stage in the instructions but "locks should cycle once for correct programming, or twice if procedure is incomplete".
Nothing happens and the fob is not programmed.
I've tried so many times .
Any suggestions please?   I did see an answer on here that perhaps the "memory" for the number of devices is full and would need to wipe all memory and start again.    I'm too scared to do this for my one and only original fob, in case it doesn't work :((
Cheers
Hi Helen1234
I went the cheap option also from Ebay for my 2010 Hilux. It took multiple attempts to get mine to work but after the 4th or 5th time it did exactly what was supposed to happen.
The instructions need to be followed perfectly and if you dont the fob will not learn the system. I was personally having the issue where the car thought I took the key out of the ignition because the key barrel is worn. I had to take my key off my key ring because the weight from my house key, canopy key and bottle opener where weighing down on the key when it was in the key barrel.
Good luck, hope you get it to work
Posted (edited)
Hi, thanks for your reply.   I'll also try taking the key off the ring.    After all,  I've tried everything else from using extreme profanities, kicking and crying.   What do I have left to lose?  Ha ha 🤬🤣
Edited by Helen1234
      Valve lifter mixed up
    2. 0
      Heat/Cold control knob not working
    3. 1
    4. 2
      Landcruiser 200 (2012) suspension swaying issue
    5. 31
      Whine in Transfer Case - 2011 Kluger
    6. 0
      Advice on new Head Unit for Corolla Levin ZR 2011
    7. 4
      GR mods
    9. 1
    10. 0
