AFTERNOON aLL
I have a 2008 Toyota Aurion (Australian build) and I have purchased an aftermarket a uniden IGO PLAY 10 to upgrade the in-car experience. However the existing radio is not BT enabled, nor does this model have an Auxiliary port. What do I need to do to make the two compatible?...OR...? ....Is there a more recent model/with interchangeability?
I think features like that have to be included with the new headunit/entertainment device.
Hi Brendan,
These days 100% will have bluetooth Android or Apple auto connections etc
The main issue will be a harness to connect everything built in standard in the Aurion (depending on what your model is ATX..Sportivo..Presara etc) to the new unit, I would read all you can about that headunit online and I also woul be extra careful before doing anything like doing it yourself if your unsure of the approach.
It may be worthwhile reaching out to a specialist car audio store like Monster or someone similar and it may even be best to dig deep into your pockets and pay someone to do the install as they will also have the right coloured plastic surround for the head unit you have to make the job look professional.
I used Monster here for my install in our Presara as I was not going to play with wiring for the steering controls to work and they did a brilliant job, I have Pics in my profile of the unit I went with and years later it is still performing perfectly.
KAA
      Front Wheel Hub Bearings...
    2. 4
      Red Liquid In Catch Can
    3. 17
      Brake issues
    4. 4
      South Africa Vs Japan Build
      Greetings Everybody
    6. 0
      Vibration
    7. 5
      New to Toyota club.
      New to Toyota Owners Club
    10. 0
