Hello everyone
Problem unlocking '01 SXV20
Ended up getting in by releasing the back passenger seat down by sticking my hand up between the seats through the boot. -
5
Red Liquid In Catch Can
I'd say he actually means the fuel filter (which in a diesel is also a water separator, hence the dash warning) -
1GD-FTV Diesel Fuel Filter
Mate I use nothing but these JSA Filters from Bretts, when work allows I call past and pick up, Top quality made in JAPAN, not chinese rubbish, and Top value for money FILTER KITS FOR TOYOTA HILUX| Brett's Truck Parts & All Filters -
G'day all, So I've just brought this car and foolishly forgot to check the locking system. First time I went to lock it only the driver's side door locked and wouldn't unlock, the other doors didn't lock. Replaced some fuses and the next time the central locking was back online. It locked all the doors and now I'm locked out. Any help with this is appreciated. It's looking like it could be a pretty expensive fix. Any advice about how to get back in would be helpful (I'm guessing coat hanger job isn't an option). I suspect ultimately the barrel may need to be replaced as it's just been warn down or possibly been jammed or some such. Thanks. PS. I've only got the one regular key, no electronic button "fob" key. Also the driver's door is only one with a key hole. -
10
Bought a spare Filter from Toyota yesterday, to carry and use if needed somewhere away from civilization. Toyota Part # 23390 0L070. Cost $73.82 Price is ridiculous. Fuel filter for my 200 only cost $38 each. Anyone know Part Number for equivalent Ryco or another brand? -
75 Series Glow Plug Query
Good morning Trying to work out how to buy correct glow plugs for my 75 series with 1 HZ diesel engine. It has a manufacture date of 04/98. Repco online product selector points me to one NGK product but lists another from 05/98 onwards. Other online sellers have same product from 1997 onwards, and others don't differentiate. (eg Sueprcheap with Bosch glow plugs) I'm in VIC and have a few frosty mornings each year. Any recommendations for glow plugs please? And were there actually modifications to the 1HZ from 05/98 onwards that mean a different glow plug is required? Regards Pete -
Rugged x 2021
Hey guys i wanna install a tub liner in my rugged x but the sports bar goes all the way down i found out that its 2 pieces and maybe theres a bracket that i can use to hold down the top piece instead of both legs -
Hello everyone. I am a new member here, and I have an issue related to the rear passenger door on the right side not locking with the other doors when I use the key to lock the driver’s door, model toyota echo 2003 sedan, I hope someone here knows what the issue is. please correct my topic if I post to the wrong place. -
2019 Toyota corolla cant find “vehicle settings” menu
same problem with you.
