...Seca Levin ?hatchback.
Hi All...
I was asked to change the blown low-beam bulb on the RH light for this vehicle.
Usually, such a thing would not be a problem - I've changed heaps on different vehicles before - but it not
being my car, I looked it up on YT first. NOT ONE of the many videos showed exactly this model, and some
said I needed to take off the front guard, while others showed the bulb replacement from just behind the
light assembly.
I can't do the latter method because on the RHS I crash into the power brakes assembly and there's just no
room to move your hand, so I'm suspecting it's removing the panel !!!
Question: Can anyone verify what I should be able to do?
Thanks, M.
Problem solved - and a correction: read above instead "...ABS assembly..."
How?
User a pair of long-nose pliers to gently pull one of the "ears" of the rubber dust cover and loosen it.
After removing that it was still a tight squeeze, but the bulb was accessible.
      Front Wheel Hub Bearings...
    2. 4
      Red Liquid In Catch Can
    3. 17
      Brake issues
    4. 4
      South Africa Vs Japan Build
      Greetings Everybody
    6. 0
      Vibration
    7. 5
      New to Toyota club.
      New to Toyota Owners Club
    10. 0
