Hi All, it is very unfortunate for me that i got Toyota Estima 2002 and had issue with transmission, and then I bought another one (because i like this car model) and got the same issue as the previous one.
the first one got 260Km and I bought it from 75Km. i changed the transmission oils quite frequently though, so I guess oil was not causing it (unless the mechanic did it wrong) and the second one I bought it 3 months ago and that was 95K imported (as usual). expecting this to be better but I was wrong. the car came with extended warranty with integrity, and they are not that helpful when dealing with replacing the transmission which only covers max $1000 and same thing with the seller as they said everything already been handed over to the warranty. so that is a bit of background, but this sad story just for me 🙂, however what I need from you guys, I want to get this fixed cheap and reliable (cheap=not overpriced)
do you have any good mechanic that can replace it cheaply (well transmissions always not cheap, as long as it is reliable and not overpriced) in Perth (Western Australia)? another question is how can I get 95Km transmissions for old car like this (2013)?
thanks to all, your help is much appreciated
    2. 1
      I have three remotes for my car but only one works
    3. 0
      Dual Fuel (LPG Petrol) FZJ105 in Adelaide - What to do with?
    4. 329
    5. 1
    6. 0
      Never before !!
    7. 2
    8. 6
      Camry Hybrid. 4.2L/100km to 7.6L/100km
    9. 6
    10. 0
      Weird Range indication on 2025 sport model
