Does ur corolla has a difference in height btw the left and right sides of the car? On mine, the gap btw the tyre and wheel arch is diff for the left and right... with the right side being lower (smaller gap)
Is this a problem?
hey same here there is a slight diff!
Posted (edited)
If you mostly drive solo and have no passengers, this is common, the drivers side will settle more than the passenger side.
There's a few things some people say you can do, but I wouldn't bother.
a: Swap springs from left to right (Why pay so much for this for a few mm?).
b: Drive around with equivalent of drivers weight on Passenger side for a few months. But this only really works when the springs are new, If they've been in there for some time, probably won't do anything but raise your fuel consumption, as the springs have already settled.
So I recommend just learn to live with it
Edited by IZZ-FE
That could also be tyre wear caused by the common camber of Australian roads.
There is a slight difference with mine as well - I can't remember which side, but it's more noticeable with the rears than the fronts. I only noticed it after lowering as well, but at standard height I couldn't tell the difference.
thats rigiht! it's more obvious with the rear than the front.. hmm...
ok my sportivo is higher on the right side when parked in my driveway coz the ground slopes from left to right ,all sportivos have a stabiliser that keeps the rear flat and even so when your car leans it looks like one side is higher but when i park on a completely flat surface is looks normal and it only looks like its uneven at the rear coz the front doesnt have a sway bar
    2. 9
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    7. 18
    8. 5
      Tow bar
