After much searching i have found some engine oils to use in my 2005 facelift sportivo....but alls i am looking for here is a straight down the line answer, no "maybe this or maybe that". my current enigne oil lookin a little too dark for my likeing so id just like to know what oil will run smoothly and efficiently in my car.
i dont mean to be rude ...i just want a plain answer so i can change my engine oil ASAP.
Thank you all.
Rob.
Thank you all.
Rob.
btw i was thinking along the lines of:
Mobil recommends the following for the 2zzge:
MOBIL 1 10W-30 or MOBIL SYNTH S 10W-40 or MOBIL SUPER S 10W-40 or MOBIL 1 5W-50 or MOBIL SUPER XHP 15W-40 or MOBIL SUPER HP 20W-50 or MOBIL SUPER GF-2 10W-30
Capacity 4.4* Litres
***BUT WHICH DAMN 1????****
Castrol Edge 0W-40 if your willing to spend a bit extra, but will provide optimal protection.
i know u said u wanted a straight answer but unfortunetly there isnt one as any oils rated from 0-40 and anything in that range so that includes 5-30, 10-30, 5-40, 10-40 and any other combination will be fine.
if you want more reading check out
Oils - Motor & Gearbox
-Synthetic Oil
-Oils aint oils
-Oil Change please help
-Changing Gearbox Oil
-Best Oil
-Gearbox Oil
-Gearbox oil and Gear shifting problems
-Oil for 2ZZ-GE engine
-engine oil
-Manual gearbox oil
-Oil usage
-Another oil question
-Oil Question
-Engine Oil
-Tranny oil for Toyota 6 speed
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
