03 Corolla Speakers
blu03rolla
i am using alpine type s and the size is 6.5 inches all doors. they just drop in with no fuss. in the boot i have a 12 inch subwoofer in a sealed box.
if you run a search you should find past topics on speakers. be careful with focal speakers in the doors as they could be too thick to fit behind the doors.
Stealth install Focal 165K2 splits. They fit in the doors no problems. Tey are quite large speakers, but still fit in without the use of spacers.
hi e-gene, did you fit your tweeters into the stock position? or do you ahve them located somewhere else?
i just got 6" JL audio splits for front
ive already got 2 12" mtx subs in the back
still looking at rears
but i dont mind 6" JL audio 2 or 3 ways
6" JVC 4 ways
6 1/2" cadence 2 or 3 ways
it comes down to what fits and what sound ya want at the end of the day.
im even considering adding 3 or 4" speakers in the rear pillar above the parcel shelf.
comes down to money and how it sounds once the original speakers are replaced.
6" JVC 4 ways
how doyo kjnow if they fit before you buy it?
  • 4 weeks later...
rear speakers only hold like a 4" speaker,, also for the people that have installed rear speakers did you have to drill out the plastic pod, because removing that speker there is no way that you can drop a 6 - 6 1/2 speaker in there are no mounting holes or screws
ok so did we work out what size speakers would fit? there seems to have been different responses from everyone...
im looking at replacing all the speakers in my corolla (as well as adding a sub :) )... as far as i know 6.5" splits will fit in the front doors... but im still not sure about the rear doors... the hole measures 5" across, so does that mean i can only get a 5" speaker in the back?
could someone please clear this up for me cos i have no idea what to start shopping for.
cheers people
i have 6 1/2 inch in front and back doors howeva i needed a spacer in the back door for a nice snug fit. the original rear door speakers are shaped weirdly and have there own spacer type thing around them. but im not sure about anyone else here weather they used spacers or not. but when i saw the size of the speaker i could swear you could possibly fit 6 by 9s in there but dont hold me to it.
I've replaced the fronts with Kenwood KFC-M1625IE (6.5" 200watt 3 way)
Used the stock speaker mount (just brutalised the existing speaker to get it out) works fine...there's about 15mm clearance between the top of the speaker and the door trim.
Yet too look at my rears but will probably replace with the same speaker.
yep kept stock door trims - the kenwoods I put in have a fairly large 'tweeter' and I was a bit nervous about them fitting but as I said above they fit with around 15mm clearance.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
