2007 TRD Aurion specifications
Engine
Type: Six cylinders, 60 degree V-formation, chain-driven DOHC with roller rockers, four valves per cylinder, all alloy, cross-flow heads, cast-iron cylinder liners
Capacity (cc): 3456
Bore x stroke (mm): 94.0 x 83.0
Compression ratio: 10.8:1
Fuel system: Sequential multi-point electronic port fuel injection with ACIS, hot-wire airflow meter
Fuel type: 98 RON PULP
Fuel tank capacity (lt): 70
Fuel economy (lt/100km): 10.9
Carbon dioxide (g/km): 257
Emission rating: Euro IV
Max. power: 241kW at 6400rpm
Max. torque: 400Nm at 4000rpm
Drivetrain
Transmission description: U660E six-speed automatic, electronically controlled with lock-up torque converter and artificial intelligence shift control
Steering
Type: Rack and pinion
Operation: Power
Turns lock to lock: 3.2
Brakes, etc
Front: Ventilated discs, 325mm x 32mm with alloy dual-piston front calipers
Rear: Ventilated discs, 310mm x 18mm with alloy single-piston front calipers
System: ABS anti-skid brakes with Electronic Brakeforce Distribution and Brake Assist
Traction Control: Std.
Vehicle Stability Control: Std.
Suspension
Front: TRD sports suspension with increased coil spring rates and re-tuned shock absorbers, ball-joint-mounted anti-roll bar
Rear: TRD sports suspension with increased coil spring rates and re-tuned shock absorbers incorporating internal rebound springs, ball-joint-mounted anti-roll bar
Wheels, etc
Rims: 19 x 8J alloys
Tyres: 245/35ZR19 93Y
Body and dimensions
Type: Monocoque, four-door sedan
Length (mm): 4890
Width (mm): 1820
Height (mm): 1460
Wheelbase (mm): 2775
Front track (mm): 1572
Rear track (mm): 1562
Ground clearance (mm): 104
Towing capacity braked/unbraked (kg): 1600/500
Seats: 5
Luggage capacity (lt): 504
ARTICLES
TRD Launches Twin Hotties: http://www.carpoint.com.au/car-review/2778149.aspx
Aurion TRD hints at Toyota excitement: http://www.drive.com.au/Editorial/ArticleD...ArticleID=42676
PHOTOS
REVIEWS
Carpoint - TRD Aurion 3500S and 3500SL - http://www.carpoint.com.au/car-review/2783028.aspx
Drive - First drive: TRD Aurion - http://www.drive.com.au/Editorial/ArticleD...p;vf=7&pg=1
GoAuto - First drive: Toyota blows sport into Aurion - http://www.goauto.com.au/mellor/mellor.nsf...A25733F00225F08
CarsGuide - TRD Aurion: mean machine with grunt - http://carsguide.news.com.au/story/0,20384...5003140,00.html
