Hi,
I am installing one of these units into my Aurion, the process is simple for this unit type as it only records GPS speed and map plotting to my phone, Horizontal/ Vertical movement (Cornering, harsh braking or acceleration) and communicates via GSM (SIM Card).
Required wires for installation:
- 12v+ Constant (Always On) for charging the tracker battery
- Earth
- Ignition
Earthing it is easy, and i'm sure i can source an ignition or acc wire from the head unit if i don't want to go directly to the internal fuse box.
My question is, does anyone know of a Constant On 12v+ source that is internal to the car? i want to install the unit behind the center air con ducts in the dash, or does anyone here have an electrical diagram i can use to source one? as well as an ignition wire that is located in the same area?
The main reason for asking this question is that i want to install the unit inside the car, without running directly to the battery.. and also to try an reduce the amount of panels that need to come off during the installation. The standard installation that we do for the Aurion doesn't suit my needs as i like knowing that some panels have never come off the car before, as well as keeping the installation hidden
Can anyone help?
