Hi All
I have read the other forum on the suspension rattle and still to NO joy still cant find the issue. Any ideas would be much appreciated.
It is a 2007 Grande (presara) with about 120000km
Started off with worn shocks that were soft and a small rattle. The rattle is only on sharp short bumps eg driving into a driveway, Driving down a rough road it is just constant but on smooth roads and under 50km, driving over cats eyes no rattle. Since replacing the struts the rattle is just horrible.
So I replaced the struts and top mounts and bearings. It immediately sounded like i had left the nuts on the struts loose. Went back and put the old struts back in with the new mounts and bearings and the rattle was quiet again. Tried another set of struts and same thing (loud rattle). So thinking that stiffer suspension may be amplifying my small rattle i went through one at a time to diagnose it and replaced tie rod ends, ball joints (since one was leaking), sway bar linkages, sway bar d bushes, and in turn found my steering rack was leaking and had that overhauled, oh and 2 more tyres because of the rack. but the rattle is still there. Had the lower control arm bushes inspected today but was told they were fine. I have been told that the inner cv joints have play and that maybe it.
In all honesty i not sure about the inner cv joints as the car drives beautifully apart from the rattle. And the rattle sounds so much like your typical worn top mount.
I'm torn on thoughts and money but cant afford to dump the car and i don't really want to either.
