I have a 04 zze122r hatch with fog lights. They do exist and are hard to come by. I got mine as a kit from ebay which included covers and the light unit. Note that the proper ones fit the facelift hatch have a specific left and right unit which have 2 screw mounts on one side and a plastic tab on the other side of each light unit. I have linked the lights below: RH side http://www.expresscarparts.com.au/productdetails/32146-toyota-corolla-fog-light.aspx LH side http://www.expresscarparts.com.au/productdetails/32145-toyota-corolla-fog-light.aspx
I dont like your chances. i would expect prices of around $1k without fitting. PM SILVABULLIT. He is a old member and should know more. Its not too hard to fit. 1 or 2 mates, a weekend and a carton of your favorite beer and you should be good.
photo attached.
04 hatch with eibach pro kit springs and koni yellows. tires are 205/50 r16 goodyear eagle f1 gs d3 .
car doesnt looked lowered until you look at side by side with stock corolla.
I have a full set of springs from a 04 ascent hatch you can have. only catch is they have been stored (lost) somewhere in the shed I think. wont have time to look for them till the weekend.
For headers you have a choice of PPE: http://www.ppeengineering-onlinestore.com/product.sc?productId=31&categoryId=15 or Wildcat: http://www.bestmufflers.com/Information/Genie/Genie_fitting_w253.htm Either headers will give you more bottom end and mid range power. They are not bolt on solutions and will need the rest of the exhaust system modded to suit as they are longer then the original header they replace.
the light housing bolts up but the plugs for the lights are different. the facelift version has a tray that all the bulbs plug into and the harness plugs into this tray
